Hello,
First of all, I am reading this very helpful forum and let me thank all the community for the great quality of information and help you provided to me.
If I would be able, it will be a pleasure to me to help others (even if I am not english language native).
I have a question for you please.
I have used for the last three years a RT-AC88U. The wifi coverage of my house is not enough, so to improve the wifi connection from everywhere, I have just bought a new router RT-AX88U.
I would like to use Aimesh in order to have a single Wifi network and create a wired backhaul. My probleme is that between I am not able to go directly between the two routers (or the main router RT-AX88U and the futur node RT-AC88U). I am obliged to put a swith between them.
Do you think it will work with the same speed rate ?
Thank you for your help
regards
regards
