AIMesh with Ethernet Backhaul
matticas
I have question and I'm not sure if this is the right place. I have two RT-AC88U routers. One upstairs in near my incoming cable line in the closet, another in my living room using ethernet to create the AIMesh. When I log in to the router I see the ethernet logo on the AIMesh node so I can tell that is working, but all of my devices on 5ghz have really low signal quality.....does the wifi from my living room not get created through the ethernet connection? I have my phone directly next to the router in the living room and it still shows weak signal in the router software , although my phone shows high signal strength. Just curious if I need to relocate the AImesh node off of ethernet and closer to the other router's wifi signal or not. thanks for any help
Could you send feedback with system log, wifi log and cfg file by Feedback function ? Please add this post URL in description field.
