Airplay issues
eastern_blok
Hi .*,
I wonder if anybody here can maybe help me. I have a AX16000 router at home and use the Merlin FW (latest 388.1), all good and pretty happy with the setup, there is only one issue I can get working on my network. I have a Home Assistant (HA) wired to the router. HA does see the homepods connected with wifi to the same router, but when I try to integrate the homepods to HA, I keep on getting these errors:
Pairing not possible
Pairing is required for AirPlay but it is disabled on the device. Please review potential access restrictions (e.g. allow all devices on the local network to connect) on the device.
You may continue without pairing this protocol, but some functionality will be limited.
I believe this is somehow a network setting related issues, but I dont seem to find what exactly it is. I do have IGMP Snooping enabled for all the Wifi bands, I did google a lot what setting could be this what restricts device to device communication on my network, but nothing what I was able to find.
Is a network expert who could help me with this?
Thanks a million and cheers!
There are two variants of HomePods - the big one and the Mini's... Mini's can act as a HomeKit hub, similar to an AppleTV 4K can...
There's also the Thread radio, which is only in the Mini HomePod, not the big one..
IGMP snooping should be turned off on the WiFi bands, as this can break multicast over WiFi, and Bonjour, along with AirPlay will be much better off...
Do you know of any other setting which dont play nice with Bonjour and Airplay. I disabled IGMP snooping for all wifi bands but still get the same error in HA. I know this is not a HA forum, but on those forums nobody could help and I didn't get any useful information.
Btw I have both the small and the big homepods, also the apple TV. all 3 have the same issues when I try to set them up in HA. HA sees them on the local network but get there 3 errors the it fail:
"Pairing not possible
Pairing is required for Companion but it is disabled on the device. Please review potential access restrictions (e.g. allow all devices on the local network to connect) on the device.
You may continue without pairing this protocol, but some functionality will be limited."
Pairing is required for RAOP but it is disabled on the device. Please review potential access restrictions (e.g. allow all devices on the local network to connect) on the device.
"Apple TV
Failed to set up device."
You disabled it for each band of wifi, hit apply at the bottom of each page and then tried rebooting?
I was having all kinds of problems playing apple music from my iphone to my homepods (4 large - 1 small).
I just applied this fix and now it works perfectly! Hands off instantly. THANK YOU
CC
What are the implications of disabling IGMP snooping?
CC
Yes I did apply it to all bands, did a restart (both HA and the router), and keep on getting the same errors.
Wonder the wired devices could cause some issues? There is a cable model (actually a router with wifi off in bridge mode) and a switch on the 10Gb port plugged in to the router...
It's not just a matter of switching the option to "Disable" - you also have to hit "apply" at the bottom of each page for the changes to stick.
Thanks a lot for pointing this out (since for the first time this was not so straight forward), but in this case this is definitely not the issue... I hit the apply for all of the bands and just after that I restarted the router. After restart I checked and all are "Disabled".
BTW this also might be helpful for my case. On the Asus router I have IPv6 turned off. But on the crapy router/cable modem one gets from the ISP (and the FW is pretty dumbed down) I dont know how things are set up. One thing is for sure if I wire (ethernet) the HA rapsi to the Asus router everything works (except the homepods/apple TV integration), but if the HA instance is wired with the cable model loads of things dont work. So the issue might be some setting on that ISP router/cable modem...:(
This is kinda the topology of the network:
things work (except homepod)
asus router <---- WAN ----- ISP router (in bridge mode)
| |------> Wifi -----> homepods
|-----> wired ----> HA instance
\-----> wired (10GB) -----> switch for other wired connections
Things are broken:
I start to suspect the ISP router is messing something here up. Might be wrong, not the network expert just a hobbyist...
Things are broken:
Ok the tool seems to remove some of the spaces on second the HA instance is connected to the ISP router...
Things are broken:
a call to your ISP tech support line should help you login to their modem/gateway equipment to check settings/update.
You should also google "what is bridge mode" so you can understand
