Allow pings from a single IP
RandInetUser
Hello,
If ICMP (pings, etc.) is blocked in the firewall, it is possible to white list a single ip?
...using SSH or Telnet, the web interface only allows to enable all or none.
Thank you
You can use the following command but I don't know how to make it survive a reboot using stock firmware.
iptables -I INPUT -s 11.22.33.44 -p icmp -j ACCEPT
*** OK forget this. I think the USB drive would be mounted before the WAN interface came up, so the changes to the firewall will be wiped out. ***
Looking at this post it might be possible if you normally have a USB drive plugged into the router.
I'm guessing you would for example create a script called /jffs/usbmount.sh containing this:
#!/bin/sh
And then trigger it at boot by setting these:
chmod 755 /jffs/usbmount.sh
nvram set usb_automount="1"
nvram set script_usbmount="/jffs/usbmount.sh"
nvram commit
Applying any WAN related changes through the GUI is likely to remove the iptables entry until the router is next rebooted.
#!/bin/sh
nvram commit
Assuming you *can* get the script started, what's to stop you from running the script in a loop, and as a background job, continually checking if the firewall rule is still there, and if not, reapplying it?
#!/bin/sh
while sleep 60; do
  <some work>
done
Yes that could work. You could even be really lazy and not bother checking for the existing rule. :D
iptables -D INPUT -s 11.22.33.44 -p icmp -j ACCEPT 2> /dev/null
