Skynet Am I blocking hacking attempts?
cc666
This is continuous on my GT-BE-98PRO log, every few seconds.
Jan 23 10:00:10 kernel: [BLOCKED - INBOUND] IN=vlan4094 OUT= (followed by a mac address)
Is this an external hack attempt being blocked?
CC
Impossible to say without seeing the source address(es) and knowing the port. Probably just port scanning.
Is vlan4094 your WAN interface?
That VLAN is a hardwire to an LG TV with a firestick. I have another VLAN hardwired to another LG TV with a firestick that is clean, no blocks.
Here is more info:
Jan 23 10:00:09 kernel: [BLOCKED - INBOUND] IN=vlan4094 OUT= MAC=xxxxxxxxxxxxx SRC=78.128.114.130 DST=ROUTER IP ADDRESS)( LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=26759 PROTO=TCP SPT=57643 DPT=33333 SEQ=2660700893 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
CC
Looks like normal port scanning. Do you see scans from other IP addresses? Perhaps you are you blocking Bulgaria in Skynet?
When I check the ip address 78.128.114.130 I get this: Other search results also indicate as malicious.
CC
