Hi
I am considering replacing an old router in my house and and extra AP I use.
I have looked at both Amplifi and unifi systems
If I buy
2xUnifi AP AC Pro
1xUnifi AP AC Lite
1xCloud key (I can even drop this one and install software on my Raspberry Pi)
1xUnifi Switch 8 ports 150W (or Zyxel GS1900-8HP)
or
1xUbiquiti AmpliFi HD Mesh WiFi system
1xUbiquiti AmpliFi HD MeshPoint
The price difference is really not that big. So I am not sure what to choose.
Unifi will give me more flexibility, cause I can extend with outdoor modules of the same type later if I want to cover bigger area. It also gives me much more flexibility.
Amplify is easy to setup, but it does not have outdoor module. It will also occupy wall outlets.
I have Chromecasts and apple tv in the house. We stream a lot, cause we do not have cable tv. We have 10-20 devices connected to network, sometimes even more.
I have I have wires in strategic rooms, so it is not an issue.
There are 3 floors in the house, where walls and roof in the basement are all concrete.
I assume stability is not the issue for these system. But how are these systems performance wise? And which one would give me best coverage?
I also have a friend that would prefer a simple to setup solution and there are no network cables in the house, only 1 place he can set his router, so for him Amplifi HD will be the best solution.
If I buy
2xUnifi AP AC Pro
1xUnifi AP AC Lite
or
