amtm AMTM and post-mount script
gk802
I notice that amtm modifies my post-mount script file and removes my own code for activating my swap file and replaces it with its own. Is there a way to override that and prevent that from happening?
UPDATE: found it. seems I needed a space following a "do-not-check-swap" comment in my post-mount script.
When things begin to fail, start there (i.e. the changes you're making).
Nothing's failing. It's a script that's been in use for years...until it was modified by an add-on. It did take a while to find the script that was modifying it...then to find why the "don't modify" comment wasn't being picked up by the grep command.
Well, that's very odd because I have in my script the "do-not-check-swap" string as a comment *without* any trailing spaces, and it's been working well and as intended for a long time since I put it there.
This is the code in AMTM:
Bash:
/tmp/home/root$ grep -A 5 -B 1 "do-not-check-swap" /jffs/addons/amtm/swap.mod
    writeswaploc(){
        if ! grep -q 'do-not-check-swap' /jffs/scripts/post-mount 2> /dev/null; then
            [ -f /jffs/scripts/post-mount ] && sed -i '\~swapon ~d' /jffs/scripts/post-mount
            c_j_s /jffs/scripts/post-mount
            t_f /jffs/scripts/post-mount
            sed -i "1a swapon $swl # Added by amtm" /jffs/scripts/post-mount
            swapon "$swl" 2> /dev/null
    remove_swap_entries(){
        if grep -q 'swapon.*\.' /jffs/scripts/post-mount && ! grep -q 'do-not-check-swap' /jffs/scripts/post-mount; then
            swtxt=" No swap file found, reference removed in\\n /jffs/scripts/post-mount"
            am=;r_m swap.mod
        fi
manage_swap(){
    if [ -f /jffs/scripts/post-mount ] && grep -q 'do-not-check-swap' /jffs/scripts/post-mount; then
        p_e_l
        echo " Found \"do-not-check-swap\" entry in"
        echo " /jffs/scripts/post-mount. Diversion and amtm"
        echo " will not auto-correct paths."
    fi
As we can see, the grep cmds don't care what's before or after the "do-not-check-swap" string.
