amtm AMTM Stuck in Screen Loop
bitmonster
Just installed a bunch of scripts on my RT-AC86U and AMTM is now stuck in a loop when opening it, refreshing here.. perhaps if I can uninstall the fw update notification script if that's causing any issues but I don't know how?
amtm 4.1 FW by thelonelycoder
RT-AC86U (aarch64) FW-386.12
Operation Mode: Wireless router
amtm - the Asuswrt-Merlin Terminal Menu
/mnt/data Size 28.1G Used 2.1G (8%)
2 open Skynet 7.4.6
5 open scribe 3.2.0
j1 open connmon 3.0.2
j3 open scMerlin 2.4.0
j6 open uiScribe 1.4.5
vn open vnStat 2.0.4
vp open VPNMON-R2 2.63
rt open RTRMON 1.58
wg open WireGuard Mgr v4.18
ep manage Entware packages
fw manage Firmware update notification
It is happening for me too.
amtm is in a refresh loop and after a few minutes it shows Segmentation Fault:
Hello,
And unfortunately it happened to me too. Installing the amtm 4.1 update, installing the notification script and it crashed when refreshing.
Is there a chance to fix this without restoring factory settings?
Hello,
Is there a chance to fix this without restoring factory settings?View attachment 55351
I believe that this has come up before. Most likely, your currently selected entware server is not accessible. Whitelist/unblock bin.entware.net, or specify an alternate.
It is not a matter of blocking or lack of access to the server.
Its not that.
Cythrawl@Dark-Router:/tmp/home/root# ping bin.entware.net
PING bin.entware.net (158.160.45.54): 56 data bytes
64 bytes from 158.160.45.54: seq=0 ttl=43 time=139.813 ms
64 bytes from 158.160.45.54: seq=1 ttl=43 time=137.175 ms
64 bytes from 158.160.45.54: seq=2 ttl=43 time=138.038 ms
64 bytes from 158.160.45.54: seq=3 ttl=43 time=135.807 ms
64 bytes from 158.160.45.54: seq=4 ttl=43 time=138.781 ms
64 bytes from 158.160.45.54: seq=5 ttl=43 time=137.023 ms
64 bytes from 158.160.45.54: seq=6 ttl=43 time=134.365 ms
64 bytes from 158.160.45.54: seq=7 ttl=43 time=139.764 ms
64 bytes from 158.160.45.54: seq=8 ttl=43 time=138.594 ms
64 bytes from 158.160.45.54: seq=9 ttl=43 time=138.927 ms
Not blocked. Still has the same issue as others above.
Seemed to happen after installing the Firmware Notification app
Fixed it.
I tried this first.
rm /jffs/addons/amtm/a_fw/amtm.mod
Still had the issue,
So I had to run this:
rm -fr /jffs/addons/amtm
Which did fix it.. Removes some email scripts and a few other small ones.. but now it is working again
Fixed it.
I tried this first.
I confirm it helped. Thank you very much!
Fixed it.
I tried this first.
Thanx for this saved my day :)
