Diversion Another RT-AC88U and Diversion question
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
cunningStunts
Question is really about the basics of Diversion. Simply put, I want to emulate what the browser extension 'uBlock Origin' does, on the rest of my network (phones, tablets, TVs, and other PCs).
From what I've gathered Diversion seems pretty simple to install, was going to go the standard version install, and it doesn't seem like there is too much setup to do.
My only worry, because I've always found networking and internet security/optimization to be harder to understand than quantum physics, is that this may interfere in some way with my significant other's job. She has to use a large banking corporations VPN from home, on this network.
Currently the AC88 log gives a "dnsmasq-dhcp[1723]: Ignoring domain....." entry when it is activated, and it works for her, so I can't risk that connection being interfered with.
So, if I install and run Diversion Standard (or Lite, not sure what the different pixlserver package routing does but there has to be a reason for this option)...will it work as well as the uBlock extension I currently use on this pc, but throughout every device connected via my router?
Apologies in advance for the scrub question and any particular info that I may have left out....my brain has issues learning this side of computing.
ColinTaylor
Part of the Furniture
Diversion is a "hosts based" ad blocker. As such it will never be as effective as browser extensions like uBlock Origin or Adblock Plus.
cunningStunts
I see.
Does it at least translate through hardware mediums? Will my TVs and mobile devices gain any shielding from ads from using Diversion at all?
ColinTaylor
Yes. Diversion is still very effective in it's own right. It can also be combined with the router's DNSFilter to intercept and (hopefully) block ads on IoT devices that try to bypass local DNS blocking. It works very well for my Sony android TV.
cunningStunts
Last questions for my peace of mind, is the program evolved enough for my silk brain to essentially 'set it and forget it' with the adblocker? IE: Install per instructions, activate adblocker (a) and activate all services (enable), update as necessary along with merlin software
Do I need to worry about learning how the other options work and operate? (history, adcount, follow, or fastswitch)
ColinTaylor
That's pretty much it. I'd probably start by installing Diversion Lite and seeing how it goes.
No.
