Another USB Mount Thread
maddbomber83
Hello;
I'm attempting to mount an external USB 3 HD to the AC68 and am encountering the 'failed to mount at the first try!' message.
For troubleshooting so far, I have tried the USB 2.0 port and also connected the drive to my windows machine and verified Check Disk ran without issue.
I've also tested a USB 3 Flash Drive in both ports (this works fine).
Any idea for the next steps on troubleshooting? Thank you in advance!
Edit: I should also add that this drive has its own battery / power and in addition is plugged into a wall adapter.
Dec  2 14:22:32 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 11
Dec  2 14:22:32 kernel: scsi7 : usb-storage 2-1:1.0
Dec  2 14:22:33 kernel: scsi 7:0:0:0: Direct-Access     Patriot  Patriot          0    PQ: 0 ANSI: 6
Dec  2 14:22:33 kernel: sd 7:0:0:0: Attached scsi generic sg0 type 0
Dec  2 14:22:33 kernel: sd 7:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Dec  2 14:22:33 kernel: sd 7:0:0:0: [sda] Write Protect is off
Dec  2 14:22:33 kernel: sd 7:0:0:0: [sda] Assuming drive cache: write through
Dec  2 14:22:33 kernel:  sda: sda1
Dec  2 14:22:33 kernel: sd 7:0:0:0: [sda] Attached SCSI disk
Dec  2 14:22:34 hotplug[2029]: USB /dev/sda1(unknown) failed to mount at the first try!
Dec  2 14:22:34 kernel: tfat: fail_safe is enabled
Dec  2 14:22:34 kernel: tntfs: fail_safe is enabled
