[ ID] Interval Transfer Bandwidth
[156] 0.0-30.0 sec 1.35 GBytes 387 Mbits/sec
[152] 0.0-30.0 sec 2.70 GBytes 774 Mbits/sec
Routing performance looks fine here.
Without CTF:
Code:[ ID] Interval Transfer Bandwidth [156] 0.0-30.0 sec 1.35 GBytes 387 Mbits/sec
With CTF:
Code:[ ID] Interval Transfer Bandwidth [152] 0.0-30.0 sec 2.70 GBytes 774 Mbits/sec
We need more details. Post some numbers, what type of Internet acces you have, how you are testing, etc...
I am using starhub fibre and I tested using speedtest.net
The hw reboot seems to be in the model ac66u not on the 68 . I am getting 20mbps on download and 100mbps on upload . I am expecting 150mbps download and 100 Mbps on upload .
No, AC68U users were also affected by the reboot issues. It was even in the AC68 374_501 release notes that they had tweaked CTF to resolve this.
In any case, seeing how I can push over 300 Mbps of traffic through it, I don't think this is a firmware issue (unless you changed something in your configuration without mentionning it, such as QoS). Also the fact that only your downstream seem to be affected - I would make sure it's not something else eating through your bandwidth.
Hey Merlin I tested with a direct connection to the modem from ISP and the port set to gigabit full duplex I was able to get 300+ Mbps upload and download . While I am connected via wireless n I only got 50 Mbps download why so?
I left the setting at n+ac
Link speed 300mbps
Max expected throughput then would be around 120-150 Mbps, depending on link quality, amount of retransmits, etc...
Try disabling Beamforming (some clients don't like it), and set Preamble to "Short".
Also, do speed tests on your LAN rather than on your WAN to better isolate the source of the slowdown. Too many variables involved otherwise.
Welcome To SNBForums
