Any Realworld AIMesh Performance Benchmarking?
Siteexperts
I currently have a Netgear Orbi connecting to Comcast Gigabit Internet. The throughput is amazing even with all the back haul via wireless (main unit connecting wirelessly to 2 satellites - house only has wiring in the basement) but the system is extremely unreliable. I have to restart it almost daily (and sometimes multiple times). Connectivity hickups were so bad that streaming HD to our TVs required me adding a dedicated set-up via moca adapters on the coax cables.
I just discovered AIMesh from Asus. I am considering replacing the Orbi with 2 AC5300 units. Has anyone reported the max throughput especially when connecting through the satellite router? or compared it to an Orbi? Does the dedicated channel create a true mesh (in case I add a third unit) and does it work well if the satellites are separated by 2 floors (or should I go with 3 units)? And how robust is the current beta firmware?
If I go the AC5300 route, I also most likely will leverage link aggregation to connect it to my qnap file server (already set-up this way). Is the AC5300 measurably faster than an AC88? Cost is secondary to having the fastest possible reliable wireless network.
I assume that means the AC-5300 is required if you want to have a dedicated channel for the mesh network (similar to the Orbi).
