AP Mode and 2.5 Gbps Port throughput
JPP PPJ
Hello anyone,
Has anyone tested real life throughput using 5Ghz-1 160Mhz with the computer next to the router on AP mode?
I am facing a case that when using the 2.5 Gbps only get 500 Mbps upload if I use one of the 1.0 Gbps ports then I can get ~900 Mbps.
I have a local speed server in my network and it seems there is QoS/rate limiting setting I cannot figure out even it is on AP mode or a bug.
PC next to router with -27dbm signal, tx/rx 2402 Mbps - ASUS - 10G Switch - Local Speed Server. If I use 2.5 Gbps port upload is ~500Mbps if I use one of the 1.0 Gbps then ~900 Mbps.
Any one who has tested the throughput? Any HW version I should look into?
