AP mode is like Charles Manson on crack!
baz
Hello all. I hope someone may be able to help me shed some light on my issue.
I was running my RT-AX88U in router mode with an RT-AC88U as an AiMesh node, and everything ran perfectly.
I just recently changed the router to AP mode after a reset (RT-AX88u) with the RT-AC88U as an AiMesh node and it is like Charles Manson on crack. As unstable as can be, The connection is very spotty and slow. I used the current stock Asus firmware on both devices and had the same problem once in AP mode. I have also tried Asus Merlin on the AX88u, and stock on the AC88U.
I have done a factory reset each time the firmware was updated/changed, but in the end, no matter the firmware (Stock, or Merlin) the same thing happens. Even without mesh running the problem persist.
I can post my system logs but am wonder whet settings I should use to debug the issue. ( Default message log level, Log only messages more urgent than)
Please let me know any thoughts or ideas you may have.
Thanks in advance for helping me trouble shoot this.
SomeWhereOverTheRainBow
What made you stop running your RT-AX88U in router mode?
baz
So I did a hard reset to both routers, and it seems things are better. Odd.....
L&LD
Part of the Furniture
Odd? I think expected. :)
