Hey y'all
Thx for reading my question, I'm trying to find an AP that will allow me to create a captive portal and limit wifi sessions to something like 2 hours per day.
I live in an apartment building that provides free wifi in the gym. The building is using a Linksys router up in the plenum to provide access, security is just a WPA passphrase given to the residents. The router is not doing any NAT or routing, simply acting as an AP.
They'd like to change that to a wifi hotspot and limit wifi session length to a daily time limit, like a maximum of 2 hours per day for example. They're concerned that people who's units are in range can just use it as their dedicated internet.
I've looked at a few models from Engenius (I've used some of their outdoor AP's) or Ubiquity, but that daily time restriction doesn't seem to be a popular/common function from what I'm seeing. I'm sure restaurants must use something like that.
I'd appreciate any suggestions for what brand or model AP I can use in this role.
I think I can do it with a ubiquity AP, but it needs a persistent connection to the controller for the captive portal function. I don't have any other Ubiquity devices and don't want to spend money on a hosted controller or a CloudKey. I could put the controller on a raspberry PI, but I'd like to find just a one device solution.
As an aside, I've already setup a DD-WRT/Hotspotsystem captive portal in the lobby, but the ability to restrict wifi sessions to a daily limit is a monthly paid feature with HotSpotSystem. However, since no residences are near enough to the lobby to abuse it, building management is OK with me limiting the wifi sessions to 15 mins or 2 GB download and users can re-connect as often as they want.
That you can do for free, but that type of security won't work in the gym.
Thank you
Thank you
