Can somebody tell me more about the pros/cons of using 40Mhz or 20Mhz Channel on the 2.4Ghz radio?
All the cool kids do the 20MHz thing in the 2.4GHz playground...
Yes but with the faster speed tiers offered now sometimes you might not have a choice but to force 40mhz on 2.4 to get what your paying for. This is not a issue for me.YET !!! In fact i have 2.4 ghz disabled it's really crowded and right now i dont need it, 5ghz works awesome here and covers my whole home.
Best case - standards compliant in 2.4GHz - 216 Mbps, which is is good enough for 20MHz channels...
Going off the range - turboQAM for some AC1900 class routers - 289Mbps - I'd recommend not going there due to 802.11b/g/n interop...
I don't understand 216 Mbps. Back in the old Linksys days when people had 5 and 7 megabit connections you could tell a difference between 40mhz and 20mhz. What am I missing?
PS
You can't save 2.4GHz. It is lost.
for a router to be certified it needs to have obss coexistence enabled and have the ability to reduce the bandwidth back to the neighborhood friendly 20mhz which means 150M max sync on 2.4 gig , forcing the router back to 40mhz will get you a max sync of 300M on 2.4 gig ( this is if the router is 300M on 2.4 gig ) and thus greater throughput
If you have the airspace to use 40mhz than you can benefit from it but this is very rare in a residential area filled with wifi. Back than there wasnt much 2.4Ghz traffic so the higher bandwidth helped.
Welcome To SNBForums
