APCS Wifi Logs AX88U
Unetwork
hi,
I don't know if this happened before, but since the flash of version 386.5_2, I have every 15 minutes or so this in the logs :
Mar 30 10:34:58 acsd: acs_set_chspec: 0x100a (10) for reason APCS_CSTIMER
Mar 30 10:34:59 acsd: eth6: selected_chspec is 0x100a (10)
Mar 30 10:34:59 acsd: eth6: Adjusted channel spec: 0x100a (10)
Mar 30 10:34:59 acsd: eth6: selected channel spec: 0x100a (10)
Mar 30 10:34:59 acsd: eth6: txop channel select: Performing CSA on chspec 0x100a
After some research, it seems to me that these lines are "normal" it would be necessary just to change the default WIFI channel which is "AUTO" and to put another one ? is it really that ?
I specify all the same that these lines of logs do not prevent the good functioning of Wifi, my devices remain connected more than 8 hours without problem or disconnection, it is very stable.
if you confirm me that these log lines are normal I would even leave the wifi channels on "AUTO" because it does not bother me.
Thanks for your help.
