Random_nonsense
Is there a way to apply a setting or config change instantly? Or force it to apply on demand. For example, if I disable internet access on a device it always seems to take a while for the change to take effect. The only way I've found to apply changes like this more instantly is to reboot the router, but then that disrupts the whole network and isn't ideal. Would there be a script command or some sort of soft reboot or refresh that I could run?
thanks!
thanks!
