Wolfschiesst
Dear All,
I am not a fan of unreasonable "voodoo" router tuning.
However, I've often read that in more noisy Wifi-environments or in configurations with multiple access points, it would be useful to set the Wifi "beacon interval" from the default value of 100 (102.4 ms) to an nearby prime number (e.g. 97 ms / 101 ms) to reduce collisions with the APs and neighbors' routers. For larger deviations, you may also need to change the DTIM to match.
But I'm really interested in what you think about it? Do you have any experience with it? Would you recommend such an adjustment?
I have carried out a few tests with changing the beacon interval and possibly reducing the DTIM to 2, but so far I have not noticed any "really" big effects.
2 Examples for such a configuration:
* Variant 1:
- Router AC88U:
2.4Ghz -> beacon interval: 101
5Ghz -> Beacon Interval: 97
- Access Point AC88U:
2.4Ghz -> Beacon Interval: 101
- Access Point AC5300:
5-1Ghz -> beacon interval: 97
5-2Ghz -> Beacon Interval: 89
* Variant 2 (seems to me to be almost the most reasonable, since all nets have different intervals):
- Router AC88U:
2.4Ghz -> Beacon Interval: 193
2.4Ghz -> Beacon Interval: 197
5Ghz -> Beacon Interval: 101
2.4Ghz -> Beacon Interval: 199
5-1Ghz -> beacon interval: 103
5-2Ghz -> beacon interval: 107
Details:
Since our house is quite large and the neighbors also run many 2.4 Ghz and 5 Ghz wifi networks, I use an Asus AC-RT88U as the main router (network access on the 1st floor), an Asus AC-RT88U as an access point on the top floor and an Asus GT-AC5300 as an access point for the ground floor including supply of the terrace and garden.
To configuration:
- No mesh connection;
- uniform, same SSID across all devices / networks;
- the two APs are each connected to the main router via a powerline backbone line.
- Smart Connect active for all (for both RT88U: for 2.4 GHz and 5 GHz each with Merlin's Asuswrt firmware; for AC5300: for 2.4 GHz and 5-1/5-2 GHz).
- The settings for Wifi networks and band control (Smart Connect Rule), which are mostly recommended in the forum.
* Variant 1:
- Router AC88U:
- Router AC88U:
Details:
To configuration:
