sebounet93
Hello,
Sorry if this subject has already been discussed but I did not find an answer to my question, I have an RT-AC88U, and I have big problems of communication between wifi devices.
It seems that it is a problem of propagation of ARP request between wifi equipments via the AC88U.
Indeed, the communications between the Ethernet and the wifi devices always work very well. The communications between equipment on Ethernet ports of the router also work very well, the communications between the 88u and the wifi devices also work very well.
On the other hand, the communications between equipments in wifi (via the 88u, they, work from time to time).
And each time when it blocks we notice that on the problematic equipment, the arp of the remote equipment is not known. The arp-who request does not arrive on the second wifi equipment. Except after a few seconds or minutes it's variable, the request forwarded and the destination equipment receives the arp-who, it answers it, and the arp finally arrives on the source wifi device...
To summarize:
ac88u to Ethernet device = OK
ac88u to Wifi = OK
Ethernet to Etherner (via ac88u) = OK
Wifi to Ethernet (via ac88u) = OK
Wifi to Wifi (via 88u) = Fail.
Arp level it gives us this:
[email protected]:/tmp/home/root# arp -a | grep 21
? (192.168.1.21) at 5c:87:30:87:de:a8 [ether] on br0
[email protected]:/tmp/home/root# arp -a | grep 56
q3s (192.168.1.56) at 20:32:33:32:46:a3 [ether] on br0
[email protected]:/tmp/home/root# date
Mon Nov 7 15:44:36 MET 2022
The RT knows the arp of the .56 as well as the .21. No problem from the router to ping these two IPs.
At the same time, I launch a ping from the .21 to the .56 no response. I trace at the same time on the router that gives me that:
nota: be focus just on capture between 192.168.1.21 (source of icmp request), and 192.168.1.56 (destination of icmp request (base of icmp reply)).
[email protected]:/# tcpdump -i br0 -n arp
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on br0, link-type EN10MB (Ethernet), capture size 262144 bytes
15:43:53.809343 ARP, Reply 192.168.1.1 is-at 3c:7c:3f:60:cc:80, length 28
15:43:54.734288 ARP, Request who-has 192.168.1.77 tell 192.168.1.77, length 28
01:00:00.898095 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46 <= why this timestamp ?
15:43:57.108258 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46
15:43:59.108250 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46
15:44:01.108147 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46
15:44:06.343590 ARP, Reply 192.168.1.1 is-at 3c:7c:3f:60:cc:80, length 28
01:00:00.099345 ARP, Request who-has 192.168.1.1 tell 192.168.1.96, length 46 <= why this timestamp ?
15:44:07.898838 ARP, Reply 192.168.1.1 is-at 3c:7c:3f:60:cc:80, length 28
01:00:00.119095 ARP, Request who-has 192.168.1.84 tell 192.168.1.88, length 46 <= why this timestamp ?
15:44:08.476215 ARP, Reply 192.168.1.84 is-at dc:f5:05:f0:0a:2a, length 46
15:44:08.764462 ARP, Request who-has 192.168.1.88 tell 192.168.1.1, length 28
01:00:00.146782 ARP, Reply 192.168.1.88 is-at 00:e0:4c:a5:df:0b, length 46 <= why this timestamp ?
15:44:15.349283 ARP, Request who-has 192.168.1.28 tell 192.168.1.28, length 28
15:44:16.464464 ARP, Request who-has 192.168.1.41 tell 192.168.1.1, length 28
01:00:00.474226 ARP, Reply 192.168.1.41 is-at dc:a6:32:0c:a0:74, length 46 <= why this timestamp ?
15:44:21.933612 ARP, Request who-has 192.168.1.101 tell 192.168.1.77, length 28
01:00:00.831260 ARP, Reply 192.168.1.101 is-at 00:e0:4c:a5:df:0b, length 46 <= why this timestamp ?
01:00:00.988578 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46
15:44:23.722006 ARP, Request who-has 192.168.1.51 tell 192.168.1.51, length 28
01:00:00.301232 ARP, Request who-has 192.168.1.1 tell 192.168.1.43, length 46 <= why this timestamp ?
15:44:23.807782 ARP, Reply 192.168.1.1 is-at 3c:7c:3f:60:cc:80, length 28
15:44:24.394553 ARP, Request who-has 192.168.1.56 tell 192.168.1.1, length 28
15:44:24.396576 ARP, Reply 192.168.1.56 is-at 20:32:33:32:46:a3, length 28
01:00:00.367627 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46 <= why this timestamp ?
01:00:00.367239 ARP, Request who-has 192.168.1.1 (3c:7c:3f:60:cc:80) tell 192.168.1.44, length 46 <= why this timestamp ?
15:44:25.872808 ARP, Reply 192.168.1.1 is-at 3c:7c:3f:60:cc:80, length 28
15:44:27.117939 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46
15:44:28.164463 ARP, Request who-has 192.168.1.96 tell 192.168.1.1, length 28
15:44:28.164763 ARP, Reply 192.168.1.96 is-at 78:a5:dd:26:df:7e, length 46
01:00:00.825869 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46 <= why this timestamp ?
15:44:55.218309 ARP, Request who-has 192.168.1.56 tell 192.168.1.21, length 46
15:44:55.456213 ARP, Request who-has 192.168.1.1 tell 192.168.1.70, length 46
15:44:55.456280 ARP, Reply 192.168.1.1 is-at 3c:7c:3f:60:cc:80, length 28
15:44:56.057136 ARP, Request who-has 192.168.1.101 tell 192.168.1.51, length 28
15:44:56.057354 ARP, Reply 192.168.1.101 is-at 00:e0:4c:a5:df:0b, length 46
15:44:56.804844 ARP, Reply 192.168.1.56 is-at 20:32:33:32:46:a3, length 28 <== after that, ping is ok between the 2 wifi devices.. no more arp-who from 192.168.1.21.
15:44:59.262719 ARP, Reply 192.168.1.56 is-at 20:32:33:32:46:a3, length 28
15:44:59.570133 ARP, Reply 192.168.1.56 is-at 20:32:33:32:46:a3, length 28
15:44:59.876987 ARP, Reply 192.168.1.56 is-at 20:32:33:32:46:a3, length 28
This is just an example, but I randomly see this behavior with other machines when they are both in wifi, sometimes it starts to answer immediately, sometimes it takes a few minutes.
Each time the arp is not known between the wifi equipment.
Do you know of a bug at this level?
Thank you in advance for your help. Very nice day to all.
Seb
PS: sorry for my English
To summarize:
ac88u to Wifi = OK
Seb
