Solved Assistance needed with file hash checking on firmware using Ubuntu
skeal
Part of the Furniture
Hey people, I for some reason forgot how to check file hash when we download firmware from Sourceforge or OneDrive. I'm using this command in Ubuntu:
$ sha256sum -c /home/steve/Downloads/RT-AC68U_386.7_2/sha256sum.sha256
and the output is this:
sha256sum: RT-AC68U_386.7_2.trx: No such file or directory
RT-AC68U_386.7_2.trx: FAILED open or read
sha256sum: WARNING: 1 listed file could not be read
UPDATE: On Ubuntu open terminal and type sha256sum and drag the firmware .zip file to the terminal window, hit enter and the hash is revealed. Compare to the website.
UPDATE: The proper file to drag to the terminal window is the .trx/.w file not the .zip file as @RMerlin explains below.
Published hashes are for the firmware image file (.trx/.w), NOT for the zip file.
Thank you sir. I was wondering what was going on. That has the situation sorted now!
