Asus 5300 firmware update
houghton19
Ive had my 5300 for about 4/5 years now, last night i noticed via the asus app that there was an update, now i judt pressed update and let it do its thing.
after the update, devices still work however i cannot log into the router now, i have tried wireless and wired. I just get a timeout page. i have tried 192.168.1.1 and router.asus.com. it still shows at 192.168.1.1 in msconfig.
Ethernet adapter Ethernet 9:
Connection-specific DNS Suffix . :
IPv6 Address. . . . . . . . . . . : fd44:b188:742c:1:a98b:7c02:3a0c:5a78
Temporary IPv6 Address. . . . . . : fd44:b188:742c:1:7871:e458:2419:733c
Link-local IPv6 Address . . . . . : fe80::a98b:7c02:3a0c:5a78%5
IPv4 Address. . . . . . . . . . . : 192.168.1.127
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
is there anyway to fix this without a factory reset as I dont have my port forwarding written down.
I have been using Merlin firmware so has this messed things up?
thanks.
Depends how out of date you were :
386.2 (2-Apr-2021)
- NOTE: due to changes in how custom device icons are handled,
first time you boot with 386.2 you need to either
shift-reload the main index page, or clear your
browser cache.
Other than that try rebooting the router and check the IP with the ASUS Discovery tool.
I don’t think I was that much out of date, I think I have sussed it, seems like I’ve either caught, or update has activated https so I’ve had to log into 192.168.1.1:8443. This has let me log in, just need to figure how to turn it off now . Thanks.
I did find out from WIZ support that these are the ports they use.
I would not have the first idea were to look on the router.
• 38899 and 38900 for UDP on local network
• 18266 on local network, for pairing
• 8883 to establish secure connection with our servers over the internet. This is the MQTT port. – TCP
• 123 - to obtain the time over the internet, for example for scheduled events, UDP
• 80 - to the internet, TCP
• 53 - to the internet, TCP and UDP to resolve Domain Name issues
• 443 - TCP to manage https
