subhasis.chemical2010@gma
Hello everybody....
I have bricked my 86U when wrong firmware upload via cfe. Massage shows: "illegal whole firmware".
After that nothing happens. No LAN connection. Reset button press not working.
Serial connection not accepting any command like ctrl+c, space etc.
please help how to unbrick my 86u..
please find cfe output in attached file...
BTRM
V1.6
CPU0
L1CD
MMUI
MMU7
DATA
ZBBS
MAIN
OTP?
OTPP
USBT
NAND
IMG?
IMGL
UHD?
UHDP
RLO?
RLOP
UBI?
UBIP
PASS
HELO
L1CD
MMUI
MMU8
CODE
ZBBS
MAIN
NAND
IMg?
IMGL
UHD?
UHDP
UBI?
UBIP
HELO
5.0202HNDrc7-1.0.38-161.122
CPU0
L1CD
MMUI
MMU8
CODE
ZBBS
MAIN
NVRAM memcfg 0x41527
MCB chksum 0xa2becbd7, config 0x41527
MemsysInit lpf0_generic_aarch64 1.3.0.1 20150910
DDR3
90001588 80018000 8001A000 00000000 00000000 0070371A
MCB rev=0x00040301 Ref ID=0x0371A Sub Bld=0x007
Dram Timing 11-11-11
DDR3-1600 CL11 total 1024MB 2 16bits part[s] %1 SSC
Add/Ctl Alignment
no adjustment
ZQ Cal LP PHY
R in Ohm
P: Finger=0x2D0 Term=0x78 Drv=0x2A
N: Finger=0x2D0 Term=0x78 Drv=0x2A
PLL Ref(Hz)=0x02FAF080 UI STEPS=0x03A
DDR CLK(MHz)=0x31B WL CLK dly(ps)=0x0C8 bitT(ps)=0x274 VDLsize(fs)=0x2A4B CLK_VDL=0x01A
SHMOO 28nm
8001A000 80018800 00000000 00020000 00000001
Shmoo WL
One UI Steps : 0x45
auto-clk result = not converged (filter=0C steps)
initial CLK shift = 01A
final CLK shift = 01A
000000000011111111112222222222333333333344444444445555555555666666666
012345678901234567890123456789012345678901234567890123456789012345678
00 S----------------------------X+++++++++++++++++++++++++++++++++++++++
01 S-----------------------------X++++++++++++++++++++++++++++++++++++++
02 X++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
03 X++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
Shmoo RD En
FORCED WR ODT = 0x18001800
DQSN DRIVE PAD CONTROL (from) (to)
B0 00031A31 00079A31
B1 00031A31 00079A31
B2 00031A31 00079A31
B3 00031A31 00079A31
B0 RISE UI=1 VDL=19 PICK UI=2 VDL=19
B1 RISE UI=1 VDL=15 PICK UI=2 VDL=15
B2 RISE UI=0 VDL=00 PICK UI=1 VDL=00
B3 RISE UI=0 VDL=00 PICK UI=1 VDL=00
00 --S----------------------X+++++++++++++++++++++++++++++++++++++++++++
01 --S--------------++++X+++++++++++++++++++++++++++++++++++++++++++++++
02 XS-------------------------------------------------------------------
03 XS-------------------------------------------------------------------
Shmoo RD DQ NP
DQS :
B0 VDL=3A ok
B1 VDL=3A ok
B2 VDL=3A ok
B3 VDL=3A ok
00 ---++++++++++++++++++++++++X+++++++++++++++++++++++++----------------
01 -------++++++++++++++++++++++++X++++++++++++++++++++++++-------------
02 ------++++++++++++++++++++++X+++++++++++++++++++++++-----------------
03 ----------+++++++++++++++++++++++X+++++++++++++++++++++++------------
04 -----++++++++++++++++++++++++X+++++++++++++++++++++++++--------------
16 X--------------------------------------------------------------------
17 X--------------------------------------------------------------------
18 X--------------------------------------------------------------------
19 X--------------------------------------------------------------------
Shmoo RD DQ P
02 -----+++++++++++++++++++++++X+++++++++++++++++++++++-----------------
03 -----------++++++++++++++++++++++X+++++++++++++++++++++++------------
04 ------++++++++++++++++++++++++X++++++++++++++++++++++++--------------
24 X--------------------------------------------------------------------
25 X--------------------------------------------------------------------
26 X--------------------------------------------------------------------
27 X--------------------------------------------------------------------
28 X--------------------------------------------------------------------
29 X--------------------------------------------------------------------
30 X--------------------------------------------------------------------
31 X--------------------------------------------------------------------
Shmoo RD DQ N
00 --+++++++++++++++++++++++++X++++++++++++++++++++++++++---------------
01 -------++++++++++++++++++++++++X+++++++++++++++++++++++++------------
02 ----++++++++++++++++++++++++X+++++++++++++++++++++++++---------------
03 ----------+++++++++++++++++++++++X++++++++++++++++++++++++-----------
04 -----+++++++++++++++++++++++++X++++++++++++++++++++++++++------------
05 ----------++++++++++++++++++++++++X+++++++++++++++++++++++++---------
06 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++---------------
07 ----------++++++++++++++++++++++++X+++++++++++++++++++++++++---------
08 ------++++++++++++++++++++++++X++++++++++++++++++++++++--------------
09 ------+++++++++++++++++++++++X++++++++++++++++++++++++---------------
10 ---------+++++++++++++++++++++++X+++++++++++++++++++++++-------------
11 ------+++++++++++++++++++++++X++++++++++++++++++++++++---------------
12 --------++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
20 X--------------------------------------------------------------------
21 X--------------------------------------------------------------------
22 X--------------------------------------------------------------------
23 X--------------------------------------------------------------------
RD DQS adjustments :
BL0: Start: 0x3A Final: 0x3A
BL1: Start: 0x3A Final: 0x3A
BL2: Start: 0x3A Final: 0x3A
BL3: Start: 0x3A Final: 0x3A
Shmoo WR DQ
00 ----++++++++++++++++++++++++X+++++++++++++++++++++++++---------------
01 ------+++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
02 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++---------------
03 -------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
04 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++---------------
05 --------++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
Shmoo WR DM
WR DM
00 -------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------
01 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++++-----------
02 X--------------------------------------------------------------------
03 X--------------------------------------------------------------------
MEMSYS init failed, return code 00000001
MEMC error: 0x00000000
PHY error: 0x00000000
SHMOO error: 0x10c00000
0x00000082
0x00000000
