I'm using 384.6 on a Win 10 laptop and for some reason I can't see the HD or Flash under "Network" or "Map a Drive" option.
The HD is a 2TB so I thouhgt that may be the issue,but then I used a 32gb flash and it does the same thing. The webpage shows the HD or Flash,but thats it.
I tripled checked settings and permissions and even did a reboot,but nothing. Not sure what else to do. Ideas/suggestions?
