Asus Ac1900 Ac68U . Recommend me router replacement antennas
MatrixGeeker
My antennas on my Asus ac1900 ac68u router is broken and I need new ones. There are so many chosen the antennas can be a long task. Im wondering if anyone knows which replacement antennas that i should purchase that will work good .
I have found that the various antennas sold by "Super Power Supply" on Amazon are reliable and provide at least as much range as the OEM antennas.
If you buy anything from Amazon note the "Support SNBForums" near the top right of this page--helps keep the doors open.
