Asus AC3200
San420baN
Routee dropped and one of the atennas came off. I tried to screw it back on the problem is the connecter Insude the router broke off. There are no screws or open spots to get inside router. Using 5 atennas instead of 6 effect the single strength etc anyone have any idea to reconnect the atennas
The screws are hidden under the four rubber feet. After removing them, you need to use something like a guitar pick to unclap the clam shell casing.
