Asus AC68U panic ( reboots )
NickG
Hi all
My router again has started to randomly reboot , really cant put my finger on what is causing it, very very random. I did have this same issue a couple of months ago or so and ended up flashing the router and then setting everything back up.
This time i have set the router to send the logs to Splunk so had a look as these are the last logs i am seeing before a gap ( reboot )
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c02cc438>] (panic+0x7c/0x1a8) from [<c00416f8>] (die+0x1ac/0x1dc)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c0043ff8>] (unwind_backtrace+0x0/0xf8) from [<c02cc438>] (panic+0x7c/0x1a8)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c016bdec>] (xz_dec_run+0x6ec/0xc68) from [<c01226c4>] (squashfs_xz_uncompress+0x108/0x254)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c016d6d4>] (xz_dec_lzma2_run+0x698/0x898) from [<c016bdec>] (xz_dec_run+0x6ec/0xc68)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c016c780>] (lzma_main+0x1dc/0xa98) from [<c016d6d4>] (xz_dec_lzma2_run+0x698/0x898)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c0387b08>] (__irq_svc+0x48/0xe8) from [<c016c780>] (lzma_main+0x1dc/0xa98)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c0387fe0>] (asm_do_IRQ+0x60/0xbc) from [<c0387b08>] (__irq_svc+0x48/0xe8)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c00678ec>] (irq_exit+0x58/0x6c) from [<c0387fe0>] (asm_do_IRQ+0x60/0xbc)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c0388388>] (__do_softirq+0xac/0x148) from [<c00678ec>] (irq_exit+0x58/0x6c)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c037c3a4>] (net_rx_action+0xb0/0x17c) from [<c0388388>] (__do_softirq+0xac/0x148)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c01f8d00>] (process_backlog+0x108/0x1e4) from [<c037c3a4>] (net_rx_action+0xb0/0x17c)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c01f8194>] (__netif_receive_skb+0x164/0x54c) from [<c01f8d00>] (process_backlog+0x108/0x1e4)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c02b7c5c>] (br_handle_frame+0x194/0x24c) from [<c01f8194>] (__netif_receive_skb+0x164/0x54c)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c0221054>] (nf_hook_slow+0xa4/0x178) from [<c02b7c5c>] (br_handle_frame+0x194/0x24c)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<c037d4c4>] (nf_iterate+0x94/0xb4) from [<c0221054>] (nf_hook_slow+0xa4/0x178)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<bf00cdf8>] (emf_br_pre_hook+0xd0/0x110 [emf]) from [<c037d4c4>] (nf_iterate+0x94/0xb4)
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<bf00b6a0>] (emfc_input+0x1e8/0x318 [emf]) from [<bf00cdf8>] (emf_br_pre_hook+0xd0/0x110 [emf])
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<bf0142d4>] (igsc_emf_enabled+0x7c/0xa4 [igs]) from [<bf00b6a0>] (emfc_input+0x1e8/0x318 [emf])
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<bf014e18>] (igsc_sdb_member_add+0xfc/0x348 [igs]) from [<bf0142d4>] (igsc_emf_enabled+0x7c/0xa4 [igs])
Jul 30 15:31:40 192.168.1.1 Jul 30 15:31:40 DSL-AC68U-6CC8-909676F-C kernel: [<bf014e18>] (PC is at igsc_sdb_member_add+0xfc/0x348 [igs])
I have attached a .txt with about a minute or so of the kernel logs just before the panic.
Anyone have any ideas on how to fix ?
Hi all
What firmware version and are you resetting that firmware before configuring it?
OE
So for firmware i had installed before was
Version 3.0.0.4.384_81981 . When i reset it i did the whole reset to factory settings etc and then updated it to the mentioned firmware and then configured it.
I just installed the latest firmware which came out 2 weeks ago or so hoping it might be ok...
Read this to understand why to reset after installing firmware:
OE
