Asus AC88U 386.1.2 firmware update - can not login to UI
Aaron Macsik
Hi there guys!
I have an interesting problem.
After I updated to firmware 386.1.2 on my AC88U, I cannot login from ANYWHERE into the router.
The login screen pops up as usual, but once I give it the username and password, hit login, it just keeps on loading and doesn't connect.
Otherwise, everything is working (so far), I have multiple devices, all connected all working, also, I can SSH into the router.
Only thing, I can not reach the router's GUI, not from chrome, not from edge, not from phone, not from the phone app.
Could you help me?
THX
Aaron
ATLga
Hi there guys!
Could you help me?
THX
Aaron
Page 1, Post 2 KNOWN ISSUES (bullet point #4)
386.1 Main Thread. You can help yourself and look for it...
Couldn't help myself - Here it is for you -
You're new, so some advice. The Better Search box at the top is a great tool. Your question for example, has literally been asked a million times.
Aaron Macsik
Thanks, actually, within an hour after I posted, it just started to work...
