Asus AC88U in AiMesh
martzmellow
Hi, new to the forum - be gentle.
I am trying to create an AiMesh with my asus AC88U as the router and an asus 1900P as the mesh node.
Both devices are running Firmware 3.0.0.4.386_43129 , have been factory reset and rebooted (several times).
Since they were both factory reset, all of the settings (except username/password and PSK) are defaults - no crazy updates or settings.
AC88U sees and connects to the 1900P, but the connection is listed as WEAK.
Even with both devices in the same room and 2 ft apart.
Setting up the mesh using wireless back haul connections since that is how I plan to use it.
Tried with Smart Connect enabled (one SSID) and disabled (two SSIDs).
I tried using a different 1900P (I have 2) and got the same results.
Tells me it is either a setting(s) I am missing, there is something wrong with my AC88U (works fine for clients tho), or the AC88U / 1900P combo is no bueno.
ASUS support was little to no help.
All they could supply was using a wired connection between mesh units (kinda defeats the purpose for me).
Please help!
Martzmellow
