Where in the menus I can see how the WIIF works and if it has errors to see what makes it better or what the issue and also for ETH to know if the cable causing issues. Tplink routers shows that
Is -93 dBm and Higher is better ? -94 dBm or lower -92 dBm? How can I make it better?
Is this good on the WIFI network ?
Is this good also? -26 dBm is better than -25 dBm or -27 dBm? How can I make it better? no matter what I do it stays the same
Sometimes this specific device get stuck on 1 / 5 Mbps for some reason and doesn't change anymore. it takes a long time for it to happen so I can't test it with each setting. It's a WIFI LED camera that capture the TV screen and shows colors behind Ambision Pro. I always have issues with this device. when first it's connected to the network it shows 2ms-5ms and then after 5-6 of that it suddenly going randomly 50-350 and it always has timeout totally random. and sometimes it can be 2ms for a whole day. I can't understand what actually make this happen, it's power cable? when I touch it's power cable it can time out somehow, but I tried like 4 power adapters so I can't understand how all of them will cause issues.
Could it be the antenna's direction that fixes this issue?
This kinda what happens it can sometimes be a lot worse
This is kinda when it's fine not perfect
