ASUS AX Series IPSEC Cipher setting(Merlin firmware)
Whitetip reef shark
Hello!! I'm using ASUS AX Series router and using Merlin Firmware(388.1 latest)
And i'm using IPSEC VPN Server feature
i wonder about IPSEC Cipher settings like aes256gcm16-prfsha384-modp2048
First. I can't found cipher settings in ipsec server settings page
Second. Checking logs i found using Strongswan 5.9.6 Server so i'm checking Strongswan homepage and found cipher settings https://docs.strongswan.org/docs/5.9/config/IKEv2CipherSuites.html
Third. I'm downloading my smartphone Strongswan apps in google play store and change cipher settings in apps like aes256-prfsha384-modp2048 then connecting my router and re checking logs. happly in logs successfully changed cipher let's see this logs
nothing change app settings: [CFG] selected proposal: IKE:AES_CBC_128/HMAC_SHA2_256_128/PRF_HMAC_SHA2_256/CURVE_25519
change app cipher settings: [CFG] selected proposal: IKE:AES_GCM_16_256/PRF_HMAC_SHA2_384/MODP_2048
these logs are same showing server and client apps but is really right changed cipher?? just only change apps settings not server??
i'm before seeing similary these question but different things i'm just change app settings but that persons using SSH entered router change server cfg files...
*****That's my wondering point, cipher change can work only change Android client app cipher settings?? or working rightly is not only enough change app settings but also using SSH connecting router and directly change server cfg??
Really thankyou for your times watching my questions :) I hope to everyone have a nice day!!
