ASUS AX6600 Reboots Randomly with Apple Devices Connected to It
CaptainVlado
I bought a new ASUS AX6600 (two units). I update the firmware and started using it, then noticed the router was rebooting at random intervals. I reset everything to default settings - no change, the router still rebooted.
I sent it back as a warranty case and got a new set. I set it up (everything standard firmware, newest version) and it started doing exactly the same.
As a next step I disconnected all LAN devices from it, including an Apple TV I had and suddenly the problem disappeared. I started plugging the devices in again and found out the Apple TV was causing the issue. I updated the OS on the Apple TV, reset it to factory defaults but the problem remained. So I disconnected it and hoped everything was fine. Then I took my iPad and connected it to the wifi and suddenly the problem was back again. I figured out it happens also with my wife's iPhone, so it looks to be any Apple device, irrelevant of type, OS, wifi or LAN.
I found another person complaining of a similar issue on Amazon (https://www.amazon.com/gp/product/RHP55DPE6W/?tag=snbforums-20) and some similar issues for other Asus routers in different forums.
Any ideas what the problem might be and what to do next?
L&LD
Part of the Furniture
Sell the apple devices. :D
L&LD
While it is true that is what I would do, it was meant to be helpful: a bump to your thread. ;)
Tech9
@CaptainVlado, post your question in the thread below. This is where people with XT8 are. Someone may be able to help you.
