Ngsaints29
Hi I recently bought an Asus AX86U router from Amazon and have it connected to my xfinity XB7 modem in bridge mode. I have xfinity gigabit internet and have the modem connected to the Wan port and it says that the status is 1Gbps which is good but then when I have my Xbox connected to the LAN port 1 it says 100mbps which is no where near gigabit. The router is on firmware 3.0.0.4.386.1_2 which is Merlin firmware. Not sure if this is a known issue or if my router is faulty. Contacted xfinity and they said I’m getting 100% of that gigabit connection to my modem so it has to be a problem with the router. Had QOS on but people told me to take it off so I did but didn’t see a difference. I have 2 Xbox’s one connected to Ethernet and one connected to 5ghz band and I’m getting the same latency on both also around 40-50 when Ethernet should be better overall. Need help ASAP
