Asus AX86U ping very high
_monster
Hello everyone :
I recently brough this router for gaming browser cs-play in Singapore server, but my router give me 350++ ping with LAN in my computer.
So I tested out with my neighbor net as well their net give me ping below 50 ( wifi )
here is the net package different between me and my neighbor
Me
- 30MBPS package
- Asus router AX86U ( Game Mode )
- Cat 7 cable
- Ping 350++
speed test
cs-play game
Neighbor
- 300MBPS
- basic router
- Wifi
- Ping 24
speed test
cs-play game
isit something wrong with my router setting ? I know there is a different between 300MBPS and 30MBP but I have a stronger router is that such huge different ? I even using cable in.
so is my router having a problem or just basic net different ? please let me know what you need to see in my router setting I post up here, thanks
Can you run a tracert to the server and post the results here. It will make it easier to see where the issue lies.
Correct,
So from this, we can see the latency is occuring between 10.233.97.55 and 10.55.200.55 which seem to be private intranet addresses (they may be isp devices)
I am guessing that the issue is occuring in the modem, or at the first hops between the router and the internet. Rather than the router itself, which seems to be performing as expected.
I am no expert, the routing that the isp is providing in that hop is where it is lagging.
I am now going to rub the magic genie lamp and call in some real experts, @SomeWhereOverTheRainBow @Tech9 @L&LD who can probably help you further.
understood, cause my neighbor having the same modem as mine, as we are order the package together. so is not normal right ? even with the different between 300MBPS and 30MBP, having 350++ ping is really crazy.
also should I ask the ISP to change their port or something or I need to get a new modem ? thanks for helping.
Hello everyone :
Me
- 30MBPS package
- Cat 7 cable
- Ping 350++
speed test
cs-play game
Neighbor
- 300MBPS
- basic router
- Wifi
- Ping 24
speed test
cs-play game
Might want to try QoS. Also other factors might be impacting ping. One thought that comes to mind is MTU, but I am stepping in gray area of my own skill set. I think there are even more knowledgeable people here such as @ColinTaylor
Sorry How too ?
Not sure am I doing it right ( same server )
mine
my neighbor
One thing that strikes me here is your neighbor has ipv6 turned on in the ping test and you don't. In this scenario you may be in a double nat like environment, where as your neighbor is not since they are using ipv6 which does not use nat. I feel like you might be using GCNAT and may need to adjust some values in the router that you will find people with other ISP than GCNAT would not normally have to change.
Hello everyone :
Me
- 30MBPS package
- Cat 7 cable
- Ping 350++
speed test
cs-play game
Neighbor
- 300MBPS
- basic router
- Wifi
- Ping 24
speed test
cs-play game
Here is a site on GCNAT. It might help you understand why your connection on it is crap.
Hello everyone :
Me
- 30MBPS package
- Cat 7 cable
- Ping 350++
speed test
cs-play game
Neighbor
- 300MBPS
- basic router
- Wifi
- Ping 24
speed test
cs-play game
One quick solution for you is to turn on ipv6. Most devices on your network will probably prefer the ipv6 connection over the crappy GCNAT connection. However this is a bandaid solution.
I wondered / noticed that as well, but I didn't have the words to explain it.
Yea I am not going to poke at GCNAT as much as I despise it, but it is one of those types of connection where the user may find themselves having to do more configurations than having internet is worth. Most people talk about the PRO'S and CON's of double-nats they have full control over, but in this instance the user only has control over their end of the NAT. The configuration can be a cake walk, or it can be a miserable experience.
I my Ipv6 is disable, what should I set ? Some asked me to turn off the Qos but is even worse, if you guys need any setting understand please let me know.
Update
After setting up my ipv6, the ping drop to below 50 but randomly, sometime is 350++ sometime is 50 below ( if I reboot the router ) no idea why.
first time
second time
I would turn off asus adaptive qos, if you need qos (others on network lagging you) get merlin with cake. It's the best option for low speed connections.
