Asus AX88U - power adaptateur
Valyno
Hello,
My router is more or less down: it boots, I can see the power Led flashing a bit, then nothing.
I can log into the admin page, but quickly the page will stop loading and nothing happens.
I would like to change the power supply, but unfortunately, I don't have a compatible one at home.
I try to buy a PSU on Amazon, but the plug is too small.
The original PSU has the following reference: ADP-45BW C.
Do you know the dimensions of the plug?
Would you have a reference to recommend, I could not find anything in Asus documentation...
Thks for your help,
Valyno
Same supply as the AC88U. Tip size: 5.5 x 2.5 mm
