Asus BE88U China model
ry0suk3
Need help with the app analysis on this router. All network traffic seem to went into TLS/SSL category on the BE88U. Is it China model having this issue? I tried, asuswrt and merlin wrt, both was showing the same result. I had no issue with my past router such as AX88U/AX89X/AX58U/AC88U. Only the BE88U unable to determine the apps that i was using through the router. Tested multiple firmware version too, none of them shows up. Did factory restore on the BE88U and also disable the trend micro agreement and enable again.
I found something weird is that the web history did indicate which web/link the device goes, but the App analysis isn't working as the same as the old router.
Could it be the router was from china and the setting inside was different? anyone using BE88U can help to see your web UI app analysis?
i can confirm its works, but only after I enabled "Apps analysis"
P.S. i dont have enabled any trend micro agreement.
I guess it's china model having this issue.. no matter which device I use. Mainly all went into TLS/ssl category.
Your be88u is non china right?
My app analysis is ON. and I been using the for 1months+, trying out all setting but still unable to get that working.
It's from Vietnam, Ver. A1, year 2024, check number 28WR. In my opinion, in this case no matter the country, is about firmware.
Btw, i have merlin 3006.102.4.
If you did not accept the TM agreement, then there must be a bug in your firmware ;)
As soon as I toggle on Apps Analysis, I am prompted with the agreement.
hmm, is prompted when I try to enable "QoS - Web History" or "Parental Controls - Web & Apps Filters".
How can I check the TM agreement for "QoS - WAN/LAN Bandwidth Monitor" ? 🤔
mine was from vietnam too, but version is 1.0. Year 2024 too. what is that check number?
Most likely Trend Micro engine issue. It's broken on Wi-Fi 7 models.
is there anyway i can fix it by manual update?
go to the admin > policy page you can from there
No idea, mby help you. Its writed on the box.
What firmware do you have now?
guess whats the price they selling the be88u in china..
i got mine brand new for around USD 235
did you install all these into your be88u? (amtm 5.2.2 / Diversion 5.4.5/ Skynet 7.6.4 / scribe 3.2.1 / ntpMerlin 3.4.6 / uiDivStats 4.0.9/ uiScribe 1.4.6 / YazDHCP 1.0.7 /email settings)
tested these firmware 102_37963, 102_38151, 102_38152, 3006_102.2_2, 3006_102.3_0, 3006_102.4_0
@sman did you do any torrenting? for my be88u, after running multiple torrent or connecting to too many client, the router stops working and all internet connection will stop working.
addons works fine now, but the first time I had some problems because I installed too many :rolleyes:
Torrenting works fine for me, but with mult-torrenting you also have to take into account PC performance, CPU + RAM and the appropriate torrent clinet settings
i had no issue even with older router like ax88u & ax89x, i can run up to 10 torrenting and up to 80MB/sec without any internet problem. the BE88U, when there was more than 20clients connected, the whole router goes down, even the webUI wasnt able to access. for be88u i connect thru tunnelbear, torrenting became very smooth and no more internet problem, just wondering is it firmware issue. feels like selling away the be88u
It seems to be a hardware problem... are there different quality standards or is it an imitation?
can you add a picture from the back of the router (with censored serial number) ?
@Ripshod @Skyview @Treadler @WTOram
I'm curious to other forum members who have BE88U from which country and what year/hardware version they have.
Made in Vietnam.
MFG. Year 2024
H/W Ver A1
Check Number 6CHB
