Purchased a Blue Cave about a month ago. When I first installed it, I ran some speed tests that were coming in at 160mbps/160mbps - right where it should be for my Frontier 150/150 connection.
About a week ago, all speedtest would not top 100mbps. The UI indicates that the port is set at 100 and it seems that it really is at 100mbps and no faster. Removing the Blue Cave from the equation solved the problem (other routers didn't have the same problem with a 100mbps speed limit, neither did connecting a laptop directly to the twisted pair coming out of the ONT.
I punted and took it back after seeing other complaints in SNB (from like 2013 or 2014) about the same problem with the WAN port. None of those threads had anything approaching a solution.
Is this common with ASUS routers?
