Asus computer with asus router
Darl
Why don't an Asus laptop work better with an Asus router? Are there any way to connect the two together?
ColinTaylor
Part of the Furniture
Thanks for the detailed problem description. :rolleyes:
AndreiV
I think the question explains the problem :rolleyes:
Darl, why on earth would you believe that an ASUS laptop/PC/tablet and ASUS router would work better/differently than when used with any other brand?
OzarkEdge
Darl
What!!! Asus does not realize with another piece of equipment like Dell or HP. I would think they would work in better COHESION.
L&LD
The best we can hope for is that everything is manufactured to the same standard. If an Asus router + any Asus peripherals worked better together than with any other brand's peripherals, it would indicate that the peripheral was better (not necessarily the router).
The question is not clear nor are there enough details posted of what the issue might be.
This thread is just a rant, for now.
