Asus DDNS workaround 10.x.x.x
Chet
I search around the internet and SNB but I couldn't find or understand a work around to my problem. Comcast just started providing me an IP that begins with 10.0.0.x and now Asus DDNS doesn't work. I don't understand why that is and how to work around the problem. Can anyone explain the issue and how I could work around the problem and get my Asus DDNS working again.
Thank you in Advance,
Chet
10.x.x.x or 100.x.x.x are private IP ranges, you have to ask your ISP to provide you a real public IP as before!
Seems they get out of public addresses so they use NAT like you in your own network.
Oh wow... that's a bit of trouble, but not unexpected...
I figured they would eventually go CG-NAT, as this is less work in the long run for them to manage...
100.64.0.0/10 - Carrier Grade NAT
Comcast does support IPv6 non-NAT'ed, not sure if Asus DDNS supports that.
Did they replace your modem? The modem comcast gave me comes with a built in router that will issue a 10.0.0.x subnet range. This resulted in a double nat.
The fix for me was:
1) Log into your comcast modem/router by going to http://10.0.0.1.
2) Put your comcast modem/router into bridge mode
I was told by the installer that nothing worked if the comcast router/modem was in bridge mode, but I crossed my fingers about 20 minutes ago and swapped it to bridge mode (ironically because my RT-AC5300 was complaining about DDNS not being compatible). Everything seemed fine to me and I have a public IP on my WAN interface for my ASUS router.
The biggest problem I see is that the firmware for the ASUS router expects the WAN IP to be a public IP. Realistically, the ASUS firmware should query an external web api or website, such as https://www.whatismyip.com to discover the external IP address and use that when it updates DDNS. My Synology NAS does just that.
Asus writes sinces 5 years that DDNS with private IP is under development and coming soon ...
