bwjliverpool
Just upgraded from DSL-AC68U to DSL-AC88U.
Is there any easy way to transfer settings easily (got lots of port forwarding variables etc) or can it only be done manually? I've tried restoring the saved CFG file from the older model on the newer one. It doesn't reject the file but it doesn't save any of the older settings either.
[PS My AC68U is probably fried - no power LED on reboot although other LEDs are on. It does come back to life occasionally when left off for a long time. May be hard for me to transfer settings with a LAN cable therefore, hence I saved the AC68U CFG file]
Thanks for any help.
