I just bough 2 of these routers and I am having some problems
Both are used as routers/AP not modems because of VOIP
1. I cannot login to the any of them remotely , I have setup DDNS in my modem router and have port forward for each one of them. I can access the login screen , but when I enter login details it just refreshes the page an at the address bar I see for a second "https://freezlo.ddns.net:8443/Main_Login.asp?error_status=6" as if the login details are not send to the router.
2. Same with SSH , it will not establish connection if not in LAN , although port forward is correct.
3. The reason I bought them was because I want to setup 2 VPNs to my RT-AX88U. They seem not to be very stable and require reboot from time to time and sometimes even if they are working fine. I cannot access the GUI at all. I can reboot it using SSH.
