Release ASUS GS-BE18000 Firmware version 3.0.0.6.102_38818 (2025/09/18)
slyx1978
Download firmware: https://rog.asus.com/networking/rog-strix-gs-be18000/helpdesk_bios/
Version 3.0.0.6.102_38818 58.16 MB 2025/09/18
SHA-256 :F22DCBAC428A57F615E5C04BE6E703BE5096BD0434223F3BCF54E50AA73A39A2
Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment.
Security Enhancements
- Password Policy Upgrade – Minimum of 10 characters, including at least one letter, one digit, and one special character; disallows consecutive identical characters; hardens defense against brute-force attacks.
- HTTPS on 8443 – Management interface now served over TLS by default.
- UPnP Disabled – Universal Plug and Play starts in the off state for reduced surface exposure.
- AiCloud Authentication Hardening (CWE-287) – Added layered verification.
- Authentication Logic Refactor – Removed redundant code paths for a lean sign-in flow.
- Memory Safety Guard (CWE-476) – Introduced null-reference protections across critical services.
- Enhanced IPsec Parameter Validation – The existing input checks have been hardened.
- Data Exposure Mitigation (CWE-200) – Reinforced controls on sensitive pathways.
- Detailed Audit Trails – Expanded logging within the authentication module.
System Improvements
- AFC Channel Priority – Raised the selection priority to increase the likelihood of switching to Standard Power mode.
- AFC Positioning Data Handling – Resolved an error where invalid location inputs blocked AFC activation.
- AFC Retry Logic – Adjusted retry behavior to avoid interference with normal AFC operations.
- Connection Stability – Core algorithms refined for steadier links.
- Scheduling Accuracy – Timed tasks execute reliably under PPPoE, PPTP and L2TP WAN modes.
- Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
