Release ASUS GT-AX11000 Pro Firmware version 3.0.0.6.102_34713 (03 June 2024)
d5aqoep
New features for ASUSWRT 5.0
-Kid's Network: Easily create a separate SSID for children's devices. Integrated AdGuard DNS offers advanced protection options, including service and website blocking, query logs, tracker blocking, and ad pop-up Ad blocking. For more details, please visit our FAQ page.https://www.asus.com/support/FAQ/1051213/
-VPN Network: Establish a VPN-specific SSID to centralize VPN settings for all connected devices. This feature allows for the importation of profiles from popular VPN services such as Surfshark, NordVPN, and CyberGhost from VPN Fusion
Please refer
Surfshark:https://www.asus.com/support/FAQ/1049833/
NordVPN: https://www.asus.com/support/FAQ/1051215/
CyberShost: https://www.asus.com/support/FAQ/1051645/
-IoT Network : Set up and manage all your IoT devices under one secure SSID.
-Guest Portal: Create a guest network with a WiFi schedule and access rights to control when and how guests can use the network.
-VLAN, allow you to segment a network into smaller, virtual sub-networks, which can be used to isolate traffic, please refer to https://www.asus.com/support/FAQ/1049415/
-Multi-services WAN, create multiple profiles on a single WAN interface. (https://asus.com/support/FAQ/1050072)
-Port isolation and AP isolation to restrict device access to each other.
Bug Fixes and Enhancements:
- Fixed an issue where the RE product ID was not being updated in the AiMesh topology.
- Corrected a display issue in the OpenVPN server that prevented IPv6 settings from showing correctly.
- Fixed a persistent GUI issue on 'Let's Encrypt Authorization' that displayed 'Authorization' incorrectly.
- Added DS-Lite Support.
Security updates:
- Addressed CVE-2023-48795 by updating the dropbear SSH server.
- Applied patches for CVE-2023-5678 & CVE-2024-0727 from the Ubuntu Repository.
- Improved security in OpenVPN custom configuration.
Please unzip the firmware file, and then verify the checksum.
SHA256: 19854a3c6b263e197fb423655685a4a8c1a3ac7e1c77f012cadeb23cb91c4d8a
Download
Thank you, I just upgraded the firmware, but I got following message in the system log,
Jun 5 07:45:02 kernel: potentially unexpected fatal signal 11.
Jun 5 07:45:02 kernel: CPU: 1 PID: 10802 Comm: firmware_check_ Tainted: P O 4.19.183 #1
Jun 5 07:45:02 kernel: Hardware name: GTAX11000_PRO (DT)
Jun 5 07:45:02 kernel: pstate: 60010010 (nZCv q A32 LE aif)
Jun 5 07:45:02 kernel: pc : 00000000f742a8e8
Jun 5 07:45:02 kernel: lr : 00000000f742a764
Jun 5 07:45:02 kernel: sp : 00000000ff9b80a0
Jun 5 07:45:02 kernel: x12: 00000000f7539c18
Jun 5 07:45:02 kernel: x11: 00000000ff9b85ac x10: 000000000023e044
Jun 5 07:45:02 kernel: x9 : 0000000000241444 x8 : 0000000000000000
Jun 5 07:45:02 kernel: x7 : 0000000000000000 x6 : 00000000ff9b81e8
Jun 5 07:45:02 kernel: x5 : 0000000000000000 x4 : 00000000ff9b8be8
Jun 5 07:45:02 kernel: x3 : 0000000000000000 x2 : 000000000000000a
Jun 5 07:45:02 kernel: x1 : 00000000f7539c18 x0 : 0000000000000000
Did you upload manually or via the webUI?
Given this initial release of 3.0.0.6.* firmware, did you Hard Reset the firmware to its default settings and then configure from scratch? If not, I'd do this next... recommission the new firmware from scratch.
FW Reset FAQ
Reset button/webUI Restore/node removal clears settings in NVRAM; reboot restores fw defaults from CFE
Hard Reset via WPS button/webUI Restore+Initialize also clears data logged in /jffs partition
OE
FW Reset FAQ
OE
I update the firmware via APP, and I will try the hardret later after my meeting. is hardret always recommened for firmware upgrade? or just firmware change from 3.0.0.4 to 3.0.0.6?
Please read the FW Reset FAQ above.
OE
You can even reset from ssh by passing comand
hnd-erase nvram
Turn off power to the router from mains and turn it back on to get “Best” reset state.
