ASUS GT-AX11000 WAN Disabled after editing LAN settings - Firmware 3.0.0.4.384_9566
abray1978
I just bought a new GT-AX11000 and set it all up without issue - great router!
Once I had everything set up, I upgraded the firmware to 3.0.0.4.384_9566
What I have noticed since upgrading is every time I go in and made a change under Advanced Settings -> LAN (for instance, DHCP reservations, etc.) - it will disable the WAN connection. I either have to go in and toggle from Enabled to Disabled and back, or pull the cable and re-insert it to bring the WAN connection back online. This didn't happen on the base firmware that the device came with - _6### something.
I took back the router and replaced with another GT-AX11000 and again everything worked until upgraded to 9566
I've attached the logs and the last entry shows that the WAN connection was "exceptionally" disconnected.
Aug 18 11:19:06 WAN Connection: WAN was exceptionally disconnected.
  • RouterLog.txt
L&LD
Part of the Furniture
Try flashing the firmware you want to use and then doing a full reset afterward. The M&M Config guide in the last couple of paragraphs in the link below may help (you can ignore any RMerlin specific steps).
raven-au
I can't quite remember now but the last several firmware releases have had problems.
I'm not sure about the DHCP reservations problem you describe, I've seen it a lot but
try rev 6436, I think that was the last best firmware IIRC.
abray1978
Thanks everyone. I've submitted feedback to Asus through the router itself. I will stick at the current firmware for now as the workaround is easy to deal with. Hopefully Asus will release a fix in the future.
