I have been unable to upgrade the speed on my Asus GT-AX11000 after Xfinity increase my speed to 2.5 Gbps from 1 Gbps. I tried increasing the speed by changing the primary WAN speed from 1 to 2.5Gbps but when I do I cannot connect via wifi or ethernet. I have tried many different configuration and rebooted both modem and router several times. I am now focused on a a possible compromise if it is dooable. Since I have both a mesh network and multiple ethernet connectionsin on the upper floor office where the equipment is, is it at least posible to increase the speed for ethernet connected devices?
Is it possible to run an ethernet line from my Cable 2.5 Gbps port to a 2.5 Gbps switch then a line from that switch to anothet 2.5 Gps switch feeding all the wall plugs, while running anothe line from the first switch to the Asus GT-AX11000, therefore giving 2.5 Gbps speed to the ethernet connections but not the wifi router?
thanks for your input.
