Release ASUS GT-AX6000 Firmware version 3.0.0.4.388.23285 (2023/05/12)
Civ
55.65 MB | 2023/05/12
Bug fixes and functionality modifications:
  • The ARP response issue has been resolved, along with the connection issue between the router and the ROG Phone 6 and 7.
  • Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
  • Resolved the Download Master login issue. Please click the update link in the USB Application to update it.
Security updates:
  • Fixed the cfg server vulnerability. Thanks to Swing and Wang Duo from Chaitin Security Research Lab.
  • Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.
Please unzip the firmware file, and then verify the checksum.
SHA256: af33eab328a4247d72299835d3e11ca4fda80f7206e4aaa331c7737b35b29d40
Just updated to this, we'll see how it does over the next day or so.
sam
What is "ARP response"
Dirty upgrade, so far so good.
No thanks.
After such an awful experience with constant wifi drops in the April update, and no mention of any stability fixes, I'm not gonna even bother.
Just downgraded to 386 as my "new firmware release", and finally enjoying some free time not trying to reconnect 50+ devices.
...please forgive my cynicism.
Did an upgrade from the previous official firmware but got a disconnection within like 30 mins requiring a router reboot so I then reset the router to factory and now it's working perfectly.
So 2 weeks later no problems with this firmware and from the lack of any posts in this thread, I'm guessing it's working for everyone else as well.
sam
Been working well for me. No problems, just keeps on cruising *smile*. Did a factory reset after the upgrade, but I was coming from 388.2_2, so I felt that it was appropriate.
sam
Indeed, very stable firmware.
Just got my router today and upgraded to latest firmware...had disconnection after that but Working perfect so far after reboot. Just trying to make sense of region setting in wifi-- professional settings. By default it's set to Asia. But I live in Australia. Should I change it ?
Greetings everyone and Thanks princi. changed to Australia region but didn't really noticed much of a change in terms of coverage/speed so Reverted back to default settings after installing some cat6 cables this morning and resetting ONT/Router. I am getting really good speed on my phone.. Pretty much same as PC. Only thing is ..on Phone my latency use to be around 5ms with old AC68U. Which is now around 8ms. Not sure if I am doing anything wrong.
I am new to tweaking around with router settings but I look forward to learning few things 🙂
The reason to change your country setting to Australia is not so that you get some sort benefit.
You might be getting good speeds but what about your neighbours? You’ll most likely be “stepping on their toes”, using frequencies that are not authorised for use in Australia, and creating problems for them.
It’s a bit like a seriously obese person sitting in the middle seat in economy - what about the people sitting next to him?
Thank princi
Just found this online. Apparently I am still a good neighbour. And I will avoid throwing popcorns on other people next flight 😀
It seems they use pretty much same frequencies
Frequency Bands: In Asia, the commonly used Wi-Fi frequency bands are 2.4 GHz and 5 GHz, following the global standard.
  • 2.4 GHz Band: The 2.4 GHz band in Asia typically spans from 2.412 GHz to 2.484 GHz, providing 13 channels with 20 MHz channel width.
  • 5 GHz Band: The 5 GHz band in Asia covers the frequency range from 5.150 GHz to 5.825 GHz. It offers a larger number of channels compared to the 2.4 GHz band, allowing for higher data rates and reduced interference
  • frequency Bands: Australia follows the standard Wi-Fi frequency bands used globally.
  • 2.4 GHz Band: The 2.4 GHz band in Australia has the same frequency range as other regions, from 2.412 GHz to 2.484 GHz, with 13 channels available.
  • 5 GHz Band: The 5 GHz band in Australia generally ranges from 5.150 GHz to 5.825 GHz. It provides numerous channels, both non-DFS and DFS channels, for improved performance and reduced interference
It's not always simply the frequencies used, the other variable is allowed power level, which can vary from region to region.
Correct
I wouldn’t want an ACMA van driving past your place with their antenna scanning the local frequency spectrum - and detecting something unauthorised.
They can issue a fine.
ACMA = Australian Communications and Media Authority
Correct
thanks for the heads up. I will look into it. also I have changed to Australian region and getting 2 extra new channels of WiFi on 2.4GHz band
