Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_37421 (2026/03/23)
Erwin
Version 3.0.0.6.102_37421
62.62 MB
2026/03/23
SHA-256 :9B5307336C381CE548DF8FDD5FBD4130CEF0BFAAC05A7D6569FF08ADDC1500AF
Bug Fixes and Enhancements
- Improved WiFi roaming behavior to reduce temporary disconnections in some scenarios.
- Improved roaming compatibility for certain client devices.
- Improved App Remote Connection stability in certain scenarios to prevent unexpected connection drops.
- Improved AiMesh onboarding reliability, addressing cases where the onboarding process could stall and fail to complete.
- Fixed an issue where the guest network client list might not display correctly in certain scenarios.
- Fixed an issue where Aura LED could turn back on after reboot even when it was manually turned off.
- Fixed an issue with Web history display.
- Fixed an issue where the app could not remove offline devices.
- Fixed an issue where specific IPv6 configuration flows could cause IPv6 connectivity problems on the main network.
- Fixed an issue where enabling System Diagnostics and staying on a specific page could cause repeated reboots.
Security Fixes
- Enhanced input validation and protection to reduce the risk of command injection and SQL injection.
- Hardened environment variable handling.
- Hardened protections around specific logging/command composition flows to reduce potential injection risks.
- Patched a command injection risk in a specific network diagnostic function.
We recommend upgrading to this version to maintain best protection.
I’m hoping RMerlin gets the latest GPLs soon, but this is a good sign…
