trameltanz
I use this router for work and I need to disable SIP_ALG so that my VoIP desk phone with PoE does not disconnected after 15 mins
I have disabled it in the NAT PASSTHROUGH tab but historically I have had to disable it over SSH
This is the command I usually run:
nvram set nf_sip=0
nvram commit
When I run nvram get nf_sip I the router from SSH it does not return any info, I get just another prompt.
So BEFORE I run the command is there a separate command built into NVRAM for this model? Is this why I do not get ANY returned data from the "nvram get nf_sip"?
Thank you for any help!
nvram set nf_sip=0
nvram commit
