Release ASUS GT-BE98 Pro Firmware version 3.0.0.6.102_37839 5-8-2025 release
cc666
Version 3.0.0.6.102_37839
69.07 MB 2025/05/08
SHA-256 959269BA810588E5C2E1490489C5FE85DB2809ACA293BF8FF35A5650E471327
Bug Fixes and Enhancements:
1. Improved compatibility with IoT devices on WPA2/WPA3 networks.
2. Enhanced the stability of remote connections.
3. Resolved an issue with the WiFi scheduler.
4. Improved Parental Control scheduling with support for SDN clients.
5. Fixed an issue causing Movistar IPTV to malfunction.
Security fixes:
1. Implemented a security patch to address an OpenVPN issue.
CC
Getting it now after receiving a notification on my router. Last time it said new firmware was available it was a false alert.
Install it today and I regret it. All my iOT devices don't connect anymore. What a nightmare.
Can I flash back?
Posting another update.
When I have to reboot or change Wi-Fi settings it takes a long time for everything to come back online. I'm estimating 30 minutes or so. Obviously not normal.
Here is my setup:
ASUS GT-BE98 Pro with this firmware
ASUS ZenWiFi BE30000 with 3 nodes in AI Mesh network paired with the GT-BE98 Pro
Here is my setup:
Decided to downgrade because of all the pain. Could not add newly purchased TP-Link matter light plugs as well as a lock Gateway I just got. No matter what setting I choose it would just not want to connect to Wi-Fi.
As soon as I downgraded all devices connected within seconds and I was able to setup new devices without any issues. I'll definitely sit this one out and wait for another update.
Wow, thats surprising. For me All my loT VLAN devices are rock solid, I have a seperate VLAN for all my Tv's rock solid, a guest VLAN perfect, a seperate VLAN for 5 cameras no problems, even MLO works great with my Pixel 9 Pro XL. I have zero complaints.
I have a total of 45 devices connected.
CC
Nog een update.
Als ik opnieuw moet opstarten of de wifi-instellingen moet wijzigen, duurt het lang voordat alles weer online is. Ik schat zo'n 30 minuten. Dat is natuurlijk niet normaal.
Dit is mijn opstelling:
ASUS GT-BE98 Pro met deze firmware
ASUS ZenWiFi BE30000 met 3 knooppunten in AI Mesh-netwerk gekoppeld aan de GT-BE98 Pro
Mlo ingeschakeld? wifi 7
Its all quiet on the ASUS side, I hope its not only for ver 3 or higher of the router. That would not bode well with me.
CC
A new ROG router featuring AFC was just released at Computex 2025, although this specific model is equipped with internal antennas. So at least they're talking about it.
I bought a BE98 Pro last week with this firmwae and has been in a nightmare with its 5G band signal strength. Not sure is it fiirmware related or hardware defective. I am getting only -80db one floor above the router casuing frequent disconnect and slow connection. My ISP provided router gives me -70 db at the same spot. TPLink BE550 gives me similar -70db too. I tried quad band smart connect or all 4 bands with their own SSID and all the same. Other than 5G band, i got perfect signal from both 2.4G and 6G band and is able to pull max ISP speed that i signed up for. Is my router defective?
Ensure that you use the same 5GHz channel when comparing signal levels. For instance, in the EU, channels 100 and above can allow up to four times more power than channels 36-44.
Thank for reminding me that. I checked again. The BE98 Pro 5G was on 80Mhz and my same as my old and ISP routers. After making sure that I think i got a defective one. I returned and exchanged for a BE96U which is on sale today for 18% off. Still took couple hours to try out different config to make every clients can connect to it reliably. Finally everything is working fast and reliably.
So I was thinking about how its been a while since I've tried dual wan on this router and decided to try it again today. Much to my surprise it switched over from the primary (xfinity) to the secondary (AT&T) and when I restored the primary it fell back like it was supposed to. Then I rebooted the router and it was able to connect itself to the primary unlike before when it would stay stuck on the secondary until I unplugged it.
I'm going to leave dual wan enabled and monitor its behavior and if I don't see any additional issues with it I'll consider it a done deal.
