ROG-Republic of Gamers | Deutschland | ASUS
Entdecke die Welt von ASUS - Alles rund um die besten Mainboards, Grafikkarten, Monitore, Notebooks und vieles mehr erfährst Du auf der offiziellen ASUS-Seite.
Clicking on the download shows no file!
Improvements:
Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
Refined accessibility-related UI and interaction details.
Enhanced stability for 2.5G LAN/WAN port operations.
Improved overall remote connection stability.
Improved system behavior when using System diagnostic on feedback page.
Bug Fixes:
Fixed incorrect connection status display for certain Wi-Fi devices.
Fixed AiMesh nodes not displayed correctly in the device list.
Fixed a disconnection issue that occurred after enabling the MAC Filter.
Fixed main network connectivity issue when enabling IPv6 for both the main network and GUEST NETWORK PRO.
Security Enhancements:
Strengthened input sanitization mechanism.
Enhanced system API validation for stronger protection consistency.
Strengthened command handling and system resource access controls.
Improved system logging and security event recording mechanisms.
Hopefully they fix the download link!
CC
